Connecting to your WiFi network with Windows 7
Here's all you need to know to connect your Windows 7 computer to your new router.
Windows 7 WiFi FAQs
You'll find both of them either on a sticker on the bottom or back of your router or on a pull-out tab at the back. If you're connecting to the Internet using one of our routers, the SSID will look something like this: PlusnetWirelessABC123 or PLUSNET-Z258.
Your wireless password is made up of ten numbers and letters.
- In the bottom right hand side of your screen you'll find the wireless connection icon (five upright bars, with a little star if you're not already connected to another network). Click on that to see which networks you can connect to at the moment
- Find your router's wireless name (SSID) in the list of networks and click Connect
- Next type in your network security key (this is the password we mentioned earlier). Then click OK. Remember, your password is case sensitive so if you're having problems, double check what you're typing
- You'll then be asked to choose a Location. A home network is a trusted network of all of the computers in your home, whilst a work network is all of those at your work. Public networks can be used by anyone, so aren't generally 'trusted networks'. Click the type of network you want to join
You might be asked to set up a Homegroup. You only need to do this if you want to use the feature with any other Windows 7 computers using your router. If you don't want to set one up now, click Cancel. If you do, click Next and follow the steps.
And that's it. You're ready to start surfing the web. If you ever want to check your connection, the wireless icon will tell you all you need to know. The bars show you how strong your signal is and if you hover your mouse over it, it'll also tell you what network you're connected to.
More ways to get help
Plusnet community
Talk to our community
Contact our team
Or call 0330 1239 123
Sign Language service
Contact us using British Sign Language
My Account
Sign into Broadband
